Call DLL (Memory error)
Please explain me, why LabVIEW Memory Manager don't like this code.
LabVIEW crashes when I call dll to find roots of polynomial.
(For my University I should make this programm without using LabVIEW function - Polinomial Roots)
:headbang:
#include "extcode.h"
#include <math.h>
#define maxiter 500
#define DBL_EPSILON 1e-9
int roots(double *a,int n,double *wr,double *wi) {...}
void deflate(double *a,int n,double *b,double *quad,double *err) {...}
void find_quad(double *a,int n,double *b,double *quad,double *err, int *iter) {...}
void diff_poly(double *a,int n,double *b) {...}
void recurse(double *a,int n,double *b,int m,double *quad, double *err,int *iter) {...}
void get_quads(double *a,int n,double *quad,double *x, short *error) {...}
typedef struct {
long dimSize;
double elt[1];
} TD1;
typedef TD1 **TD1Hdl;
extern "C"{
__declspec (dllexport) long Polynom(TD1Hdl coef, TD1Hdl mr, TD1Hdl mi, short *error);
double a[21], x[21], quad[2], wr[21], wi[21];
int n, numr, i;
n=(*coef)->dimSize-1;
for(i=0; i<=n; i++){
a=(*coef)->elt;
if ((n < 1) || (n > 20)) {
*error=1;
goto out;
*error=0;
// get coefficients of polynomial
if (a[0] == 0) {
*error=1;
goto out;
*error=0;
if (a[n] == 0) {
*error=1;
goto out;
*error=0;
// initialize estimate for 1st root pair
quad[0] = 2.71828e-1;
quad[1] = 3.14159e-1;
// get roots
get_quads( a, n, quad, x, error);
roots( x, n, wr, wi);
numr = roots( x, n, wr, wi);
(*mr)->dimSize=numr;
(*mi)->dimSize=numr;
for (i=0; i<=numr; i++){
(*mr)->elt=wr;
(*mi)->elt=wi;
out:
return 0;
Full code and VI:Download File:post-4254-1148137671.zip
a=(*coef)->elt;
*error=1;
goto out;
*error=0;
Are you sure the coef array never contains more than 21 elements? You index it before you error out if it would contain more!
(*mr)->elt=wr;
(*mi)->elt=wi;
You can't just set the dimSize of an array without making sure it is big enough to hold that many information. Before setting the size you should at least use the LabVIEW memory manager function NumericArrayResize or something like that.
Rolf Kalbermatter
Thanks for your answer! :yes:
This really work. :D
Changed code:
if (err = NumericArrayResize (fD, 1, (UHandle*) &mr, numr))
goto out;
if (err = NumericArrayResize (fD, 1, (UHandle*) &mi, numr))
goto out;
for (i=0; i<numr; i++){
(*mr)->elt=wr;
(*mi)->elt=wi;
