Holy Macarony
post-4885-1150569548.jpg?width=400
:D:D:D
I was cleaning up my inline code and just by curiosity i was looking at the invoke node methods for sub VIs. What do i find ?
Yes, an inline method.
It has a "makespace" and the possibility to wrap the code in a sequence frame. I tested it, just replaced it with my inline tool, and - it works. I have not tested it thoroughly, so i do not know the requirements etc.
Well, at least there should be no problem to write a nice app that inlines VIs :thumbup:
Now that you have found that, all you need is a VI that recursively in-lines all subVIs. You should be able to use the resulting sequence structure reference to traverse for subVIs. Want an easy way to traverse? Just use <LabVIEW 8.0\vi.lib\Utility\traverseref.llb\TRef Traverse for References.vi>.
Cheers,
-Jim
