datamgr.cpp error
I was doing some changes in one of my control when I've receive this error. I've check at NI and there's no indication about this error. Now I can't run my main program anymore. :throwpc:
Do you have any idea of what's wrong?
Thank you,
post-3808-1151423610.jpg?width=400
Thank you,
I guess that your control is corrupted. If it is a typedef, try opening the control file only. If it crashes LabVIEW, use revert to a backup copy or send it to NI, they may be able to fix it.
Is your control HUGE (cluster with hundreds of elements)? That might be the problem
You were right... I think. When I've saved my control, I didn't notice but I've save it in .ctt instead of .ctl. I've changed that and it correct my problem.
Thank,
coolaid
