seoul Posted July 28, 2006 Report Posted July 28, 2006 I had some database programme which were programmed in LV 7.0. They can run in LV7.0. But when I install LV8.2, these programme can't read or write data to database. And there is an error"-2147352571" The reason said by LV8.2 is: Error -2147352571 occurred at Rec Destroy - Connection.vi->DB Tools Select All Data.vi->子界面-历史图形.vi Possible reason(s): 类型不匹配。 in DB Tools Fetch Table Data.vi->DB Tools Select All Data.vi->子界面-历史图形.vi The chinese reason means "Type mismatches ". I don't know why, :headbang: why I can't use these programmes in LV8.2 HELP!! :worship: Quote
Ton Plomp Posted July 28, 2006 Report Posted July 28, 2006 Hello Seoul, If I were you I'd contact the NI helpdesk. Because 8.2 is not released yet, so the beta help is you goal. Ton Quote
crelf Posted July 28, 2006 Report Posted July 28, 2006 But when I install LV8.2... Looks like you're getting the "You have broken the temporal continium" error - it's standard when you're using something from the future. The easiest way to fix it is to stop and wait for time to catch up Quote
