plneo Posted August 2, 2006 Report Share Posted August 2, 2006 Hello everyone, I wonder if anyone can advise me what is happening in this VI? (Note that my VI is only partially completely for its purpose.) I have an array that is generated outside the 'for' loop. All I want to do is to use the 'for' loop and get a subset of the externally-generated array. The 2 'for' loops are used to calculate the index of the required subset of the array. However, when I do the wiring, it seems to be that the external for loop is truncating my 2D array into a 1D array. What is happening here? Is there any way I can pass in an externally-generated 2D array into the 'for' loops for subsequent processing? Thanks. Download File:post-5479-1154533521.vi Quote Link to comment
jhoskins Posted August 2, 2006 Report Share Posted August 2, 2006 Hello everyone, I wonder if anyone can advise me what is happening in this VI? (Note that my VI is only partially completely for its purpose.)I have an array that is generated outside the 'for' loop. All I want to do is to use the 'for' loop and get a subset of the externally-generated array. The 2 'for' loops are used to calculate the index of the required subset of the array. However, when I do the wiring, it seems to be that the external for loop is truncating my 2D array into a 1D array. What is happening here? Is there any way I can pass in an externally-generated 2D array into the 'for' loops for subsequent processing? Thanks. Right click on the input terminal of the for loops ans disable auto-indexing this will stop the for loop from indexing the array at the input. Quote Link to comment
