PJM_labview Posted August 22, 2006 Report Posted August 22, 2006 Bug Description: If you create the attached VI and put a custom probe (which happen to be a conditional string one by default) on the queue refnum wire and run the VI, LV crash (regardless of the queue element type). If you put a generic probe everything is fine. Mostly the problem arise when LV decide all you want are custom probes (even when you just select right clik>Probe [and not custom probe]) and put a conditional string custom probe by default on this type of wire. Workaround: Be sure never to have a conditional string probe on queue refnum wire. PJM Quote
PJM_labview Posted August 22, 2006 Author Report Posted August 22, 2006 Bug Description: If you create the attached VI and put a custom probe (which happen to be a conditional string one by default) on the queue refnum wire and run the VI, LV crash (regardless of the queue element type). If you put a generic probe everything is fine. Mostly the problem arise when LV decide all you want are custom probes (even when you just select right clik>Probe [and not custom probe]) and put a conditional string custom probe by default on this type of wire. Workaround: Be sure never to have a conditional string probe on queue refnum wire. PJM Download File:post-121-1156258747.vi Quote
Aristos Queue Posted August 23, 2006 Report Posted August 23, 2006 This was reported to R&D (# CAR ID 40LHJ4J1) for further investigation. Quote
