mac/windows over the network... with Labview
tibobo
Hello guys,
I have many computers acquiring datas, and I need to read and write these datas from a single ethernet hard drive (LaCie 500 GB, FAT32).
On a Mac G5 with LV8, once the ethernet drive is mounted in the finder, I try to read a simple config (or text or binary...) file in labview, but I get an open/create/replace file code 10 error.
I've got the same behavior with a file located on a PC hard drive (mounted in the Finder too), but I don't have any problem with a file on a Mac hard drive.
It works when I try the same from a PC with LV8. For me, all this tells it's related to smb/cifs stuffs...
I tried manual path entries like : "file://Volumes/GRESSENSGRP;U676-BACKUP/Datas/file.txt", etc... but nothing works. I didn't find the same problem in the forums...
Any idea ?
thanks
Boris
  tibobo said:
Hello guys,
Any idea ?
thanks
Boris
First I have no experience with Mac/finder.
Error 10 is a duplicate path error, I've only seen these when copying a file into it's own, or creating an existing folder. Maybe it is an access rights thing. A quick test might be a VI with only an open file vi, this will launch a browser so you can open the file, if this still give an error (and you can open the file with another application) it might be a bug.
Ton
Hi Ton,
Thanks for your post.
  Quote
I get alternatively an error 10 or an error 7 depending on the open vi I use (config file, file,...)
  Quote
I tried with a simple vi and I get an error. I also tried to use a read-only option, and there shouldn't be any right access on this drive. When I ask them in the Finder, I have read/write permissions.
What is strange is that I'm able to use the list folder vi with no error. If I use the output to build a path and then open it I get an error.
You're right, it should be an access rights problem... but I can't figure out how to solve it...
Boris
I don't have ethernet hard drive, but read text file or ini file from PC hard drive works on my G5. (Mac OS 10.4.6, LV8.2 - PC hard drive formated in FAT32).
Can you give us more information about your configuration ?
ptit bras
I tried on a G5 10.4.7, LV 8.0.1, and on a Powerbook G4 10.4.7, LV8.0.1, to read files from PC hard drives formatted in FAT 32 and NTFS (both don't work). I had problem with file transfers in my network in the past (strange things such as file not readable anymore after transfer) and I probably should search this way...
Thanks for the test anyway :beer: !
Boris
