Changing the root palette
  Michael_Aivaliotis said:
I'd like to change the palette that shows up first when I right-click on my diagram. Is this possible? If so, how?
Specifically, I'd like to set the programming palette as the root palette. I'm using LV8.20
The only way I know to achieve something somewhat similar is to switch to the Palette View "Category (Standard)" and then whichever palette is top most (this can be changed as seen below) will show up first.
post-121-1158302641.png?width=400
PJM
PJM
Now in LV 8.2 you get a message about the saving of the root.mnu, it looks like it is moved from menus\default\root.mnu to personal\LV data\8.2\pallettes\menus\default\root.mnu
I'm not sure what is happening but maybe you can create a new root.mnu in you personal folder which has everything you want?
Ton
post-2399-1158309694.png?width=400
