Is it possible to have a LV Webservice web resource with a variable in the middle of the URL?
Specifically - I am looking at emulating an existing REST api that is in the style:
/command1/command2/<variable>/command3-related-to-variable
one example where this occurs is with network devices port or VLAN ids  (eg:   <url>/port/3/speed    )
Obviously if it is my REST api,  I could just do /port/speed and have a variable passed for the port number  (eg:   /port/speed?port=3 ) -- but I don't get to define everyone's API...
In my case, I am trying to emulate such behavior, so I need to setup a web resource that (ideally) would behave identically to the API,  hence  /port/3/speed  etc   is desired.  But I see no obvious way to do so in LV (2024 SP3)
Edited by bobenose
Answered:  https://www.ni.com/docs/en-US/bundle/labview/page/understanding-url-mappings-and-query-strings-in-web-services-real-time-windows.html?srsltid=AfmBOopGM5Aom7rH3ofPKKWSHNo1Ye6RrmFtwG6Zh_QJFtInuTGsTOJO
Future me (or you) - simply set the Web Service Properties ->  HTTP Method VI settings -> URL Mapping  to something such as  <base url>/path1/path2/:variable1/path3/:variable2 )   and variable1 and variable2 will be passed into the VI as a path parameter rather than the query parameter (eg:  <base url>/path1/path2/path3/?variable1=___&variable2=_____ )
  • Thanks 2
