XML scripting
bsvingen
There is a bunch of XML Script VIs in LabVIEW 8.2\vi.lib\_script\XML Scripting Does anyone know what these are for? Is it something to come, or can it be used now?
If my memory serve me well, these VIs are use by mathscript. Everything that came with your LV can be used. There are actually gems in vi.lib that are unfortunately not exposed on the palette. In regards to these script VIs, If you can figure out the abstraction NI build over scripting, I see no reason why you should not use them.
Note: Here is a gem I found in that folder as well (Connector Pane Terminal Order.ctl)
post-121-1159401082.png?width=400
PJM
PJM
That's pretty neat, but I've always (since scripting )wondered how to handle the rotation of the connector pane.
Aside from that, these XML files look like a pre-cursor to something new w/ lv as a whole w/ regards to scripting and porting of VIs
How to handle it? Well, you have the rotation methods for the connector pane:
post-1450-1159887585.jpg?width=400
We can do it all, but adding new patterns. It would be necessary a xnode for that, and is not so simple :(
Saludos,
Aitor
Sure, it's easy to make the rotation, but how do we determine orientation after the fact and re-intepret the connector order/traversal.
I'm not sure if I understand you, but in the ConPaneData property you have that, isn't it?
Saludos,
Aitor
