alukindo Posted October 13, 2006 Report Posted October 13, 2006 After I made corrections to a user.lib VI, the functions palette has disappeared when invoked via Tools>Advanced>Edit Palettes. Has anyone come across this and knows of a fix? ... I repaired and unistalled/re-installled LabVIEW but this did not resolve the problem. Quote
Ton Plomp Posted October 13, 2006 Report Posted October 13, 2006 After I made corrections to a user.lib VI, the functions palette has disappeared when invoked via Tools>Advanced>Edit Palettes. Has anyone come across this and knows of a fix? ... I repaired and unistalled/re-installled LabVIEW but this did not resolve the problem. I have seen the same, but am not sure what i did to fix this. Best was to have nothing open but LV, and minimize the LV windows afte selectin edit palettes. It looked like the palettes where hidden behind VI windows... :headbang: Ton Quote
LAVA 1.0 Content Posted October 13, 2006 Report Posted October 13, 2006 It get's lost outside the visible screen area. To fix the problem, remove the Labview ini file or alternatively remove all lines from ini that are related to functions palette. Quote
alukindo Posted October 14, 2006 Author Report Posted October 14, 2006 I think that deleting the LabVIEW ini file would have done it. I was able to recover from this by un-installing LabVIEW 8.2 and then deleting the entire LabVIEW 8.2 folder, and then re-installing LabVIEW 8.2 Note that uni-installing LabVIEW via Windows>>Control Panel>>Add-Remove programs and then re-installing LabVIEW did not work! Thank you Ton and Jimi for replying to my post! Quote
