alnaimi Posted October 16, 2006 Report Posted October 16, 2006 hI ALL, i have a LED ,, I have the LABVIEW CODE FOR EMIITING THAT LED , now I want to emit a real LED using LABVIEW with interfcaing with KPCI card so could u plz help me?? Quote
Khalid Posted October 17, 2006 Report Posted October 17, 2006 What card are you using? I am guessing it is some kind of a DO card. Is it supported by LabVIEW/NIDAQ? Can you test it under MAX? Thanks, -Khalid Quote
alnaimi Posted October 17, 2006 Author Report Posted October 17, 2006 my card is KPCI 3100 !! but what is MAX?? Quote
Khalid Posted October 17, 2006 Report Posted October 17, 2006 my card is KPCI 3100 !! but what is MAX?? MAX is short for Measurement and Automation eXplorer -- National Instruments' hardware configuration software. You would use this to configure your hardware boards and devices. Who makes this JPCI 3100? Do they have VIs for it? -Khalid Quote
James N Posted October 18, 2006 Report Posted October 18, 2006 alnaimi, You are talking about a Keithley PCI card, right? I've used the KPCI-PIO96 before. You'll need to install the DriverLINX software from Keithley. I believe this should have come with your hardware or a free download. The VIs are very similar to the NI DAQ VIs. Follow these links for some clues.. http://www.keithley.com/products/software/...are/?mn=LABVIEW http://www.keithley.com/products/software/.../?mn=DRIVERLINX http://www.keithley.com/products/dataacqmo...s/?mn=KPCI-3101 -James Quote
