i2dx Posted October 16, 2006 Report Posted October 16, 2006 Hi Folks, I can't get rid of the error messages, generated by the automatic error handling. I have a "Clear Errors" VI, which has an "error in" Input, an "error out" Output and a "no error out" where - you guess right - no error comes out. I use this VI to clear the error wire, but "see" the error anyhow. If I don't connect the error out Output, I get one of these automaic error dialoges, which I don't want to have, because I'd like to "silently suppress errors" with this VI. I thought I could turn of automatic error handling for the VI with the VI properties. But even with disabled "Enable automatic error handling" I get the error dialog. What can I do to get rid of the error dialoges? thank you in advance and cheers :beer: CB Download File:post-885-1161016140.zip Quote
crelf Posted October 16, 2006 Report Posted October 16, 2006 i2dx said: If I don't connect the error out Output, I get one of these automaic error dialoges, which I don't want to have, because I'd like to "silently suppress errors" with this VI. I thought I could turn of automatic error handling for the VI with the VI properties. But even with disabled "Enable automatic error handling" I get the error dialog. If I'm understnading you correctly, you've disabled automatic error handling in the VI you attached - what you need to do is disable it in the VI that calls that VI - that's where the errors are handled since it realises an error is coming out of your subVI and isn't connect to anything - it's only once it gets out of the subVI and is properated up to the calling VI does it realise it's not being handled and pops up the dialog. Quote
Aristos Queue Posted October 16, 2006 Report Posted October 16, 2006 crelf said: If I'm understnading you correctly, you've disabled automatic error handling in the VI you attached - what you need to do is disable it in the VI that calls that VI - that's where the errors are handled since it realises an error is coming out of your subVI and isn't connect to anything - it's only once it gets out of the subVI and is properated up to the calling VI does it realise it's not being handled and pops up the dialog. I opened up the VI and took a look. Christopher is correct. The subVI's configuration doesn't matter. It's the caller VI that has to be configured to not do automatic error handling. You have a subVI that is returning an error, and that error is not handled. You can either turn off auto error handling in the caller or handle the error -- wiring the output terminal to anything is sufficient, as shown: Quote
i2dx Posted October 16, 2006 Author Report Posted October 16, 2006 Aristos Queue said: ... You can either turn off auto error handling in the caller ... hpmf ... I knew it was a realy stupid mistake thx Quote
crelf Posted October 16, 2006 Report Posted October 16, 2006 Aristos Queue said: I opened up the VI and took a look. Christopher is correct. Whew! Quote
Aristos Queue Posted October 18, 2006 Report Posted October 18, 2006 crelf said: Whew! Heh... didn't mean to conflate those two sentences. I didn't intend to cast doubt on your diagnostic prowess. Quote
januar Posted November 12, 2006 Report Posted November 12, 2006 I have made some simple program to disapble automatic error handling. If you need it you can use it. Download File:post-4552-1163331104.zip Quote
crelf Posted November 12, 2006 Report Posted November 12, 2006 januar said: I have made some simple program to disapble automatic error handling. If you need it you can use it. Mmmm - this VI has potential. It could be useful as a part of a tool that does a whole bunch of stuff to your VIs before you build, archive, etc. Perhaps as a component of the OpenG builder? Quote
i2dx Posted November 13, 2006 Author Report Posted November 13, 2006 crelf said: Mmmm - this VI has potential. It could be useful as a part of a tool that does a whole bunch of stuff to your VIs before you build, archive, etc. Perhaps as a component of the OpenG builder? hey, my frontpanel (<CR>!) tool does the same and more! and you did not mention it in a word <sniff> .oO(but I guess, I will survive that ) Quote
crelf Posted November 13, 2006 Report Posted November 13, 2006 i2dx said: ...and you did not mention it in a word <sniff> C'mon idx2 - you know I can't play favorites Quote
i2dx Posted November 13, 2006 Author Report Posted November 13, 2006 crelf said: C'mon idx2 - you know I can't play favorites okok, I just wanted to play the prima donna :beer: and as I write this, it comes to my mind, that I could make the frontpanel tool even more generic. Maybe I could even convice NI to add that functionality to the application builder? Quote
crelf Posted November 13, 2006 Report Posted November 13, 2006 i2dx said: okok, I just wanted to play the prima donna :beer: and as I write this, it comes to my mind, that I could make the frontpanel tool even more generic. Maybe I could even convice NI to add that functionality to the application builder? That's what I'm talkin' about - a really generic util that could accept plug-ins. I wouldn't want it added to the app builder, but I'd like a way to call whatever I wanted from the app builder instead... Quote
i2dx Posted November 14, 2006 Author Report Posted November 14, 2006 crelf said: That's what I'm talkin' about - a really generic util that could accept plug-ins. I wouldn't want it added to the app builder, but I'd like a way to call whatever I wanted from the app builder instead... hmm ... creating plugins would be easy, thanks to VI Server and SubPanels. Let's start a Project and a new thread? Quote
crelf Posted November 14, 2006 Report Posted November 14, 2006 i2dx said: hmm ... creating plugins would be easy, thanks to VI Server and SubPanels. Let's start a Project and a new thread? Good idea - go for it! Quote
