Re-submitting code
Hello all,
I recently submitted some code to be in the code repository but it was rejected for a very minor issue. My question is this, to re-submit do I have to start all over with the submission process. Or can I simply upload a new .zip file with the fixed code?
I tried looking around for a place to re-upload my zip but I couldn't find any thing. I looked in my control panel, and in the section of the code repository that I submitted my code to. Thanks.
...it was rejected for a very minor issue.
:D
Can you see this page?
I apologize for this technical issue. I am aware of this. Currently, when you submit a file, it creates a page that is ONLY visible by the CR reviewers. Once your submission is approved, it will then be visible to yourself and everyone. Then, you can click on the "edit" link to update the file, no need to start again. This issue is already noted and is going to be addressed in a future release of the LAVA CR.
For now... I will go ahead and approve your old submission, however you MUST go and update it with the new file. Look here at the bottom for instructions on how to update an exisitng file:
http://forums.lavag.org/index.php?showtopic=3470
So now if you go here you should be able to edit your file and replace it with a new one.
http://forums.lavag.org/index.php?automodu...amp;showfile=48
  • 3 months later...
