LAVA 1.0 Content Posted November 6, 2006 Report Posted November 6, 2006 Hi, If I connect a child class type to a static class member VI of the parent class, the static member VI preserves the child class type passing trough the VI. This is a very nice feature and simplifies programming. However, if I connect a dynamic dispatch wire to such a VI, the class type is preserved but the "dynamicity" is not. This is a bit annoying since I cannot then pass a dynamic wire to a static member VI as I have no way of casting it back to a dynamic wire. So is this intended feature for some reason or a bug? EDIT: Oops... This problem occurs only if the static member VI is inside a polymorphic VI and you drop the polymorphic VI to the block diagram instead of dropping the static VI directly. So it sounds like a bug to me as I assume polymorphic VIs should act exatly as the VIs inside it. Quote
Aristos Queue Posted November 7, 2006 Report Posted November 7, 2006 Yeah... sounds like a bug. It's late tonight... if you don't see me post a CAR number here tomorrow, remind me later in the week. Later edit: This was reported to R&D (# 436FPTJ1) for further investigation. Quote
