Cool-LV Posted November 8, 2006 Report Posted November 8, 2006 Hi, Anybody knows how to set an image as a wallpaper programatically ? thanks @! Quote
Akash Bhakta Posted November 8, 2006 Report Posted November 8, 2006 There are properties on the Pane class in VI Server that you can use to get/set the wallpaper. They are Background Image, and Background Mode. E.g. -Akash Quote
Cool-LV Posted November 9, 2006 Author Report Posted November 9, 2006 There are properties on the Pane class in VI Server that you can use to get/set the wallpaper. They are Background Image, and Background Mode.E.g. -Akash Hi Akash, Thanks for your answers, Maybe I havn't given the details, my wallpaper isn't LV front panel background image, but it is computer's destop wallpaper. and your thread is supported at LV8.2, mine is LV7.1 (I can't find your thread at LV7.1 and LV8.0) . Quote
Dirk J. Posted November 9, 2006 Report Posted November 9, 2006 this VI calls the SystemParametersInfo function from user32.dll. Download File:post-3523-1163065125.vi Quote
Cool-LV Posted November 10, 2006 Author Report Posted November 10, 2006 this VI calls the SystemParametersInfo function from user32.dll.Download File:post-3523-1163065125.vi Dirk J. Thank you very much, Yup, this is what I am looking for, but it since support BMP image only ? fail to JPEG picture. Quote
Khalid Posted November 10, 2006 Report Posted November 10, 2006 Dirk J. Thank you very much, Yup, this is what I am looking for, but it since support BMP image only ? fail to JPEG picture. The wallpaper (eventually) has to be a BMP. When you are manually setting a JPEG, for example, as your wallpaper, Windows actually makes a copy of this to a BMP format and uses that for the wallpaper. Check out the 'Wallpaper' and 'ConvertedWallpaper' regisrty entries under HKEY_CURRENT_USER\Control Panel\Desktop. Regards, -Khalid Quote
Cool-LV Posted November 10, 2006 Author Report Posted November 10, 2006 The wallpaper (eventually) has to be a BMP. When you are manually setting a JPEG, for example, as your wallpaper, Windows actually makes a copy of this to a BMP format and uses that for the wallpaper. Check out the 'Wallpaper' and 'ConvertedWallpaper' regisrty entries under HKEY_CURRENT_USER\Control Panel\Desktop.Regards, -Khalid Oh, thanks, to be this ! I know now. Quote
dbyers3 Posted June 12, 2007 Report Posted June 12, 2007 humm... I am trying this with LV8.2 and windows XP SP2. and the background is not changing.. Any Ideas why it's not changing background pictures? Quote
dbyers3 Posted June 13, 2007 Report Posted June 13, 2007 QUOTE(dbyers3 @ Jun 11 2007, 01:23 PM) humm... I am trying this with LV8.2 and windows XP SP2. and the background is not changing.. Any Ideas why it's not changing background pictures? Disreguard,... My other test machines work fine on this code. Just one machine doesn't. Probably screwedup gov OS. :worship: Quote
Rolf Kalbermatter Posted June 13, 2007 Report Posted June 13, 2007 QUOTE(dbyers3 @ Jun 12 2007, 09:08 AM) Disreguard,... My other test machines work fine on this code. Just one machine doesn't. Probably screwedup gov OS. :worship: Could be a policy setting disallowing the change of the desktop background. Window policy editor does allow a myriad of settings being changed, that control such things as this. Rolf Kalbermatter Quote
