The challenge with the labview7.1
alameer
I am guessing you would like to communicate with the two PLCs using LabVIEW. Please write in detail as to what exactly you are trying to accomplish.
The Delta PLC uses the Modbus protocol as per the attachment. And I am again guessing -- based on your previous posts -- you have been able to communicate with it. What communication protocol does the Omron PLC use? Alternatively, does it come with an OPC Server?
Also, please share any details and VIs that you have tried so far.
Regards,
-Khalid
I want the work of the SCADA systems of irrigation and agriculture, needed to link with the LV PLC and here I want to ask how they link Do I need OPC or another there Shi
It depends on the communication protocol the PLCs use. Please find out the exact communication protocols the PLCs use. We can then discuss the options available for communicating with LabVIEW.
-Khalid
