Modbus RTU & Labview (Berger Lahr Axle)
Harry1984
English
Hy @ all!
I want to control a axle from Berger Lahr (Schneider Electric) with Modbus under
the environment LabView 8.20
Unitl now I have tried a lot to make the thing work...
http://zone.ni.com/devzone/cda/tut/p/id/4722
... use the Modbus library respectively
http://zone.ni.com/devzone/cda/epd/p/id/4756
Because of the fact that I am a greenhorn in connection with "Modbus", I am not sure how to
make the axle work, which busregisters I should use, ...
These are the files which are improtant for the task:
The VI (Attachment)
modbus.vi
The Modbuslibrary
ftp://ftp.ni.com/pub/devzone/epd/nimodbus.llb
The Modbus Manual of the Axle/Contoller
http://www.berger-lahr.com/upload/DokuDB/D..._V104_TE_EN.pdf
I really hope, that you are able to help me
Thank you for your time
Greetings from Austria
Harry
Deutsch
Hallo Ihr!
Ich m
... I am not sure how to
Hello Harry,
Looking at the manual briefly, it doesn't list the Modbus addresses for the parameters explicitly anywhere. However, sections 5.4 and 5.5 do list some examples. In these sections, the register addresses are specified in paranthesis. You will want to contact the device manufacturer to get a complete of Modbus register addresses.
Gut gl
Is there any VI in which I only have to put in the addresses and everything works?
Hello all,
in my firm, we have implemented ModBus Protocol (over serial and TCP connexion). You can download here an exe demo witch allow you to try communiction with your device... of course, it's not an implementation of NI modbus library, but perhaps it can help you...
ciao
