Jim Kring Posted December 4, 2006 Report Posted December 4, 2006 I have a design question regarding the encoding of special characters in INI file section and key names (for example, if you have an EOL or other special character in your section/key name). This relates to an improvement being made to the OpenG Variant Configuration File IO VIs that allow variant data to be written to and read from INI files. I have posted the design question, here. Your feedback and participation in this process is appreciated, since many people rely on these VIs. Thank you, Quote
Aristos Queue Posted December 4, 2006 Report Posted December 4, 2006 http://forums.openg.org/viewtopic.php?p=1067#1067 said: * \00-\0F (non-printable chars)* "[", "]", and "=" (INI syntax elements) * \r and \n (EOL characters) * \FE (" Quote
Jim Kring Posted December 4, 2006 Author Report Posted December 4, 2006 Aristos Queue said: You should probably avoid the first 32 characters (00 through 31 decimal). The ini files are pure ASCII files, and the first 32 characters are "unprintable". The biggest problem would be character 26, aka ctrl+z, aka the end-of-file indicator. Writing it into the file as part of a key value would result in the end of file being assumed whether it was really the end of the file or not. That would mean using your escape sequence for \00 through \1F. It would encompass the \r and the \n characters. Yes, you are right about \00 through \1F, Actually, the code I wrote already did \00 through \1F, but somehow the VI documentation and my posting/question stated \00 through \0F. But, my code also redundantly included \r (\0D) and \n (\0A). I've fixed that, now. Quote
