alukindo Posted December 8, 2006 Report Posted December 8, 2006 See attached VI code snippet. Should'nt the result be FALSE? Well it is TRUE in LabVIEW 8.2 . . . Any thoughts? Quote
crelf Posted December 8, 2006 Report Posted December 8, 2006 Should'nt the result be FALSE? I'm not convinced, but I'll leave it to the pros to point out why... Quote
Darren Posted December 8, 2006 Report Posted December 8, 2006 From the LabVIEW 8.2 Online Help for the And Array Elements function: "Returns TRUE if all the elements in Boolean array are TRUE. This function also returns TRUE if Boolean array is empty because TRUE is the identity for the Boolean AND operation. Otherwise, the function returns FALSE. This function accepts an array of any size but returns only a single value based on all values in Boolean array. " I remember asking this question a while back...I think lots of people have asked it in the past, which is probably why that sentence is now in the Help. -D Quote
jpdrolet Posted December 8, 2006 Report Posted December 8, 2006 I'm not convinced, but I'll leave it to the pros to point out why... There was a famous thread on Info-LabVIEW about this issue... Maybe it is easier to begin with the numeric array function _Mulltiply Array Elements_ (MULT(A)) which shows a similar behavior: when applied on an empty array, the result is 1 which is the neutral element of the multiplication. For example if the array A contains N identical elements X then the result MULT(A) is X^N. Then if A is empty a consistent definition for the result is X^0 = 1. This also makes sure that MULT(A|B) (where | denotes array concatenation) always equals MULT(A)*MULT(B) even in the cases where A or B is empty (that wouldn't be true if MULT(empty) was defined to 0). The same logic applies to boolean AND array elelements. If you want AND(A|B) to be always equal to (AND(A) and AND(B)) AND(A|B) = (AND(A) and AND(B)) Now if B is empty the A|B = A AND(A) = AND(A) and AND(empty) which is valid only if AND(empty) = TRUE. The heart of the argument on Info-LabVIEW was a poster that insisted that since the logical operator 'and' is a binary operator (it operates on two arguments) it didn't make sense to apply it on arrays of 0 or 1 element; the result should be undefined. However AND(A) is a different operator, conveniently defined on arrays, a definition including 0 and 1 element arrays: AND(A) == 1 and A[0] and A[1] ... and A[N-1] Quote
Ton Plomp Posted December 8, 2006 Report Posted December 8, 2006 Nick Storton gave an explanation at NI.com. It is something natural in the array and function. Ton Quote
