alameer Posted December 26, 2006 Report Posted December 26, 2006 welcome i doing projet as shown below by using DAQ & LV 8 and use PWM i take signal from DAQ which refer to voltage which converted to Actual theta (Numirc . this theta must be compered with desired Theta with Actua 1- if Acutal theta greter than Desierd theta must be decrese the PWM 1. 2-if Acutal theta less than Desierd theta must be increse the PWM 1 3- if Acutal theta equal Desierd theta must be outputing this signal by PWM here my try , here iam SubVI PWM as shown but i, can't found any result !!! summry : how i can get the desired theta by using PWM ? i need help thanks Quote
Ton Plomp Posted December 27, 2006 Report Posted December 27, 2006 Hello Alameer, First forget the dynamic data type, you never use it in your code. Have the Daq assistent put out a Voltage (or better the theta, but that is another exercise). Then probe what theta comes out, is that correct? Another tip, use executed highlighting. Ton Quote
