problem with prject
alameer
welcome
i doing projet as shown below
by using DAQ & LV 8 and use PWM
i take signal from DAQ which refer to voltage which converted to Actual theta (Numirc .
this theta must be compered with desired Theta with Actua
1- if Acutal theta greter than Desierd theta must be decrese the PWM 1.
2-if Acutal theta less than Desierd theta must be increse the PWM 1
3- if Acutal theta equal Desierd theta must be outputing this signal by PWM
here my try , here iam SubVI PWM as shown
but i, can't found any result !!!
summry :
how i can get the desired theta by using PWM ?
i need help
thanks
