alnaimi Posted December 27, 2006 Report Posted December 27, 2006 hi , is there is any icon for oscilloscope in LABVIEW???? Quote
Doon Posted December 27, 2006 Report Posted December 27, 2006 Are you looking for an Oscilloscope-type indicator? Then I would suggest using the Waveform Chart indicator. Under the "Appearance" tab of the indicator properties, you will find a combo-box labelled "update mode". With this, you can set the indicator to display like an o-scope. I hope that helps, 8D Quote
alnaimi Posted December 27, 2006 Author Report Posted December 27, 2006 Are you looking for an Oscilloscope-type indicator?Then I would suggest using the Waveform Chart indicator. Under the "Appearance" tab of the indicator properties, you will find a combo-box labelled "update mode". With this, you can set the indicator to display like an o-scope. I hope that helps, 8D THNXXX ALOT but any other suggestion Quote
AnalogKid2DigitalMan Posted December 27, 2006 Report Posted December 27, 2006 Make your own ******* icon in the built in icon editor???????? Quote
Albert Geven Posted December 27, 2006 Report Posted December 27, 2006 I have added a nice empty vi with an old hp scope icon. Download File:post-175-1167249814.vi Quote
Mark Balla Posted December 28, 2006 Report Posted December 28, 2006 hi ,is there is any icon for oscilloscope in LABVIEW???? There are some built in ones if you have loaded the NI Scope drivers. Quote
