Remote VISA timeout takes longer than expected
bbean
Can someone help explain why the attached code takes longer than ~1 sec to execute if my network connection is down. As you can see in the NI Spy screenshot it takes >15 secs.
If the network is down I ASSume the 1000ms timeout should abort the VISA open. I know I shouldn't assume.
post-549-1168470539.jpg?width=400
:headbang:
:headbang:
I had a similar problem a while back with "remote" FPGA open which is really just a special VISA open. The FPGA open/close/read/write timeouts can not be set. So, one solution was to use a VISA open with a custom timeout. I experienced the same problem and just gave up... Heres the post at NIs website.
