"Wait on Notification from Multiple" output values can be wrong on timeout
Jim Kring
[CAR 45E9BHJ1]
The "Wait on Notification from Multiple" function seems to have a bug in how it sets "notifiers out" in the case of a timeout. If an instance of "Wait on Notification from Multiple" is called successively (for example, in a loop), calls that timeout will pass out notifiers (in "notifiers out") from previous calls which did not timeout. I would expect "notifiers out" to be an empty array if the function times out.
See "TEST - Wait on Notification from Multiple.vi" (attached) for an example that demonstrates this bug. In this example, "Wait on Notification from Multiple.vi" is called twice in a For Loop. On the first iteration a notification is successfully received and on the second iteration a timeout occurs. On the second (timeout) iteration, the value of "notifiers out" contains the notifiers that there fired on the first call. I would expect "notifiers out" to be an empty array if the function times out.
Download File:post-17-1168812196.vi
