NAGWI Posted January 19, 2007 Report Posted January 19, 2007 Hi, I am trying to generate Pulse from the Labview configureing Ctr0 as output and aquiring the same pulse using Ctr1 input. Setup details: NI 6602 Card as been used LABVIEW8.2 I connected output PIN (Ctr0)to Input PIN (Ctr1) using a wire as a loopback. When I run the VI ..it is generating a error. Here I am attaching all the screen shots related to DAQAssistant. Regards, NAG Download File:post-7395-1169210702.zip Quote
karthik Posted January 20, 2007 Report Posted January 20, 2007 Hello NAG, Can you plz give details about error occured? I have done same loop back test many times ... I never faced any problem ... May be you are missing some thing minor... If possible post your code ...(In 8.0) Regards, Karthik SP Quote
NAGWI Posted January 22, 2007 Author Report Posted January 22, 2007 Hello NAG,Can you plz give details about error occured? I have done same loop back test many times ... I never faced any problem ... May be you are missing some thing minor... If possible post your code ...(In 8.0) Regards, Karthik SP Hi Karthik, Could u plz post the setup details and block diagram.I have attached everything in the first post itself. Regards, NAG Quote
Ton Plomp Posted January 22, 2007 Report Posted January 22, 2007 Hi Karthik,Could u plz post the setup details and block diagram.I have attached everything in the first post itself. Regards, NAG Hello NAGWI, could you convert the DAQ assistant into normal code? (right click and than 'convert to VIs' or something similar) And what is going wrong? You did not mentioned that in your first post Ton PS I see you make progress in asking questions :thumbup: Quote
NAGWI Posted January 22, 2007 Author Report Posted January 22, 2007 <br />Hello NAGWI,<br /><br />could you convert the DAQ assistant into normal code? (right click and than 'convert to VIs' or something similar)<br />And what is going wrong? You did not mentioned that in your first post <img src="style_emoticons/default/wink.gif" style="vertical-align:middle" emoid=" " border="0" alt="wink.gif" /> <br /><br />Ton<br /><br />PS I see you make progress in asking questions <img src="style_emoticons/default/thumbup1.gif" style="vertical-align:middle" emoid=":thumbup:" border="0" alt="thumbup1.gif" /><br /><br /><br /><br />Please find the attached CODE file and Error message JPG file. -NAG Quote
