LAVA 1.0 Content Posted January 27, 2007 Report Posted January 27, 2007 Hi, I'd need to get a reference to a LabVIEW Class that is currently in memory. All I have is the class name in a format "MyClass.lvclass". The problem is that I don't know the path of the class but only that the class is currently in the application memory. If there is a way to get a reference using the class name, that would be superb. If this is not possible, is there a way to get the path of the class if you just know the name and that it's currently in memory. jimi If I get a reference to all VIs in memory, that is fine as well. Quote
Ton Plomp Posted January 28, 2007 Report Posted January 28, 2007 If I get a reference to all VIs in memory, that is fine as well. Jimi the following code (8.2) should do that: Download File:post-2399-1169973721.viDownload File:post-2399-1169973693.vi Ton Quote
LAVA 1.0 Content Posted January 28, 2007 Author Report Posted January 28, 2007 Jimi the following code (8.2) should do that:Download File:post-2399-1169973721.viDownload File:post-2399-1169973693.vi Thanks Quote
LAVA 1.0 Content Posted January 29, 2007 Author Report Posted January 29, 2007 It worked... Each class always has a typedef, the name of which is of the form MyClass.lvclass:MyClass.ctl. One can open VI reference to this typedef using Open VI reference and a technique described by Ton. Having retrieved this reference one can then find out the library into which the typedef belongs to. I however noticed that I really needed the reference to the typedef itself and not the class. jimi Quote
