Jim Kring Posted January 31, 2007 Report Posted January 31, 2007 [CAR 41HDO7D5] In LabVIEW 8.2, it appears that the Delete file primitive has a nasty little bug, in that it ignores the confirm input, which is supposed to present an OK/Cancel confirmation dialog box to the end user, before deleting the file (or folder)! Cross-posted to ni forums, here. Quote
Grampa_of_Oliva_n_Eden Posted January 31, 2007 Report Posted January 31, 2007 Jim Kring said: In LabVIEW 8.2, it appears that the Delete file primitive has a nasty little bug, in that it ignores the confirm input, which is supposed to present an OK/Cancel confirmation dialog box to the end user, before deleting the file (or folder)! Cross-posted to ni forums, here. Ouch! This reminds of an old Dilbert cartoon. Dilbert is sitting in front of his PC and we can read the mesages on his screen. "Preparing to install software" "Clearing hard drive" "placing order for software updates" Ben Quote
Jeff Plotzke Posted January 31, 2007 Report Posted January 31, 2007 Jim Kring said: In LabVIEW 8.2, it appears that the Delete file primitive has a nasty little bug, in that it ignores the confirm input, which is supposed to present an OK/Cancel confirmation dialog box to the end user, before deleting the file (or folder)! Jim, I find that the confirm works correctly and asks for confirmation only if you leave the file input unwired (to use the file dialog)... But you're right, it ignores it if you wire in a file name... :headbang: Quote
Jim Kring Posted January 31, 2007 Author Report Posted January 31, 2007 Jeff Plotzke said: I find that the confirm works correctly and asks for confirmation only if you leave the file input unwired (to use the file dialog)... But you're right, it ignores it if you wire in a file name... Jeff: Thanks for the extra info. I hadn't tried leaving the file input unwired. Seeing as how an empty path is actually the root folder of the file system (/), this could have been a dangerous test Quote
gmart Posted January 31, 2007 Report Posted January 31, 2007 This issue has been reported to R&D (CAR 41HDO7D5). Quote
Jim Kring Posted January 31, 2007 Author Report Posted January 31, 2007 gmart said: This issue has been reported to R&D (CAR 41HDO7D5). Thanks! Quote
