Ton Plomp Posted January 31, 2007 Report Posted January 31, 2007 Crosspost warning Has anybody succeeded in placing an Xcontrol in the palette of the Front Panel? I tried but have not succeeded..... :thumbdown: Ton Quote
Doon Posted January 31, 2007 Report Posted January 31, 2007 tcplomp, Using the "Link to Directory" method, I had no problems getting xControls to show up. -H Quote
Jim Kring Posted January 31, 2007 Report Posted January 31, 2007 Has anybody succeeded in placing an Xcontrol in the palette of the Front Panel?I tried but have not succeeded..... Ton, Create a VI with and instance of the XControl on its Front Panel and then edit the palette such that this VI is set as a "Merge VI". See here: Merging VIs in a Palette Set Thanks, Quote
Ton Plomp Posted January 31, 2007 Author Report Posted January 31, 2007 Ton,Create a VI with and instance of the XControl on its Front Panel and then edit the palette such that this VI is set as a "Merge VI". Thought about that but it just seem unnatural. At home it works, I think I seriously have to reinstall my work laptop... (that will cost me a day or 2!). On interesting thing is that at home I couldn't find my controls palette when editing. Had to edit my labview.ini to get it back. (was probably gone when dual monitoring) Ton Quote
Michael Aivaliotis Posted January 31, 2007 Report Posted January 31, 2007 Tried this in 8.20. Go into Tools>Advanced>Edit Palette Set Then pick the XControl from your hard drive location. Quote
