Multicolumn Listbox Edit Cell Event Bug
gleichman
This bug causes typed data entered the time before last to disappear. (Does that make sense?) Here's how it works:
  1. Click on cell 1 and enter data.
  2. Click on cell 2 and enter data.
  3. Click on cell 3 enter data and then click outside of the listbox.
  4. Data in cell 2 disappears.
To perform this magic trick, your code must have the following.
  • Set the "Edit Position" when the listbox is clicked on.
  • Trap the "Edit Cell?" event.
I've attached a simple example (LV8.2) and cross posted to the NI forums (no CAR and no responses).
Download File:post-151-1170292612.vi
I requested an AE look at your post.
If you do not see action in the next 48 hours, PM me and I will push harder.
Ben
  • 2 years later...
There was this :
http://forums.lavag.org/Multicolumn-Listbo...-Bug-t6071.html
Now the same with an EditPos used in a Shortcut Menu Selection (User).
So, here's the plan (thanks to the true writer) :
  1. RightClick "Add" on cell 1 and enter data.
  2. RightClick "Add" on cell 2 and enter data.
  3. RightClick "Add" on cell 3 enter data and then click outside of the listbox.
  • Set the "Edit Position" when the listbox is "rightclicked" on.
Does anyone have an idea ?
Have you ever seen this bug ?
This is not critical for me, but I'm surprised that this bug haven't been corrected yet : I checked it with LV8.6.1 and LV8.5.1.
