alameer Posted February 2, 2007 Report Posted February 2, 2007 welcome for all i have one Q : how used the DSC in Labview 8 to make 1- data logging . 2- Securtiy . 3- Alarms . 4- Networking . 5- Trends . for irrigation System Model contains 1-CONTAINER ( analog Value ) 1- Pump ( Digital Value ) 5 - Sensor Valve ( Digital ) 1- Tensiometer ( analog Value ) . totaly : 2 values analog . 6 values digital . i will use DAQ Card to read values digital and analog . Quote
Jeff Plotzke Posted February 2, 2007 Report Posted February 2, 2007 alameer said: how used the DSC in Labview 8 to make 1- data logging . 2- Securtiy . 3- Alarms . 4- Networking . 5- Trends . This is a pretty vague question... If you haven't used LV DSC before, I'd start with LabVIEW Help / DSC Examples. They can give you a start for how to use DSC. I think NI has some examples/tutorials on their site as well. Quote
Rolf Kalbermatter Posted February 5, 2007 Report Posted February 5, 2007 alameer said: welcome for all i have one Q : how used the DSC in Labview 8 to make 1- data logging . 2- Securtiy . 3- Alarms . 4- Networking . 5- Trends . for irrigation System Model contains 1-CONTAINER ( analog Value ) 1- Pump ( Digital Value ) 5 - Sensor Valve ( Digital ) 1- Tensiometer ( analog Value ) . totaly : 2 values analog . 6 values digital . i will use DAQ Card to read values digital and analog . You could also have asked how to use a computer to create a program. Basically by learning the tools you have available for your use. LabVIEW DSC is specifically an add on to solve most of those problems a bit easier although it is by far not a requirement. But giving you here a run down of what to do would be mostly a copy of the Getting Started with LabVIEW DSC manual and I would assume you have that at your hands. Rolf Kalbermatter Quote
