gustav Posted February 5, 2007 Report Posted February 5, 2007 Is it possible to use VI server calls to get a reference to a VI inside a built application on a remote computer, if the remote computer does not have the labview development environment installed? I guess what I'm really asking is if the VI server is included in teh LV runtime engine or only in the development environment. I would be thankful for any answers . /Gustav Quote
Jeffrey Habets Posted February 5, 2007 Report Posted February 5, 2007 Yes, this is possible.. Just make sure that you have an ini-file with the same name as your application's executable and make sure you enable tcp/ip access to your app. You can copy these settings from your labview.ini. I think it's something like: server.tcp.enabled=True server.tcp.access=+* to enable unrestricted access to your app. Quote
gustav Posted February 5, 2007 Author Report Posted February 5, 2007 Yes, this is possible..Just make sure that you have an ini-file with the same name as your application's executable and make sure you enable tcp/ip access to your app. You can copy these settings from your labview.ini. I think it's something like: server.tcp.enabled=True server.tcp.access=+* to enable unrestricted access to your app. Thanks, that sounds like exactly what I needed to know. And an impressively fast response too ! Quote
gustav Posted February 5, 2007 Author Report Posted February 5, 2007 I got it to work, allthough I had no luck with the ini files so I used an application property node instead. Thanks! Quote
Rolf Kalbermatter Posted February 5, 2007 Report Posted February 5, 2007 I got it to work, allthough I had no luck with the ini files so I used an application property node instead. Thanks! You might have forgotten a piece that was omitted in the original post. If your application is called MyApp.exe create an ini file called MyApp.ini in the same directory and add: [MyApp] server.tcp.enabled=True server.tcp.access=+* Bascially the exact settings can be best configured in the LabVIEW development system and then copied over to your ini file but it is important to adapt the ini file header to match your application name. Leaving the VI server open entirely does not seem to be a very good idea to me. Rolf Kalbermatter Quote
