Anders Björk Posted September 17, 2008 Report Posted September 17, 2008 QUOTE (Phantom_Lord @ Sep 15 2008, 10:47 PM) Quote I think you are referring to the point by point section: I tried that, but I would prefer using spectral measurement because it supports windowing and averaging without further coding...Thanks for your reply! Well you have this Vi that uses waveform input and not Dynamical inputs which expressvis do. http://lavag.org/old_files/monthly_09_2008/post-5713-1221561700.jpg' target="_blank"> Quote
Phantom_Lord Posted September 17, 2008 Report Posted September 17, 2008 QUOTE (Anders Björk @ Sep 16 2008, 10:41 AM) Quote Well you have this Vi that uses waveform input and not Dynamical inputs which expressvis do. http://lavag.org/old_files/monthly_09_2008/post-5713-1221561700.jpg' target="_blank"> Yes, in fact I've done in a similar way; I've downloaded the circular buffer VI but it doesn't work with my labview version. This is however a simplified version of what is going on in my VI (the FFT here is done on 10 samples and is updated every sample). Quote
Anders Björk Posted September 17, 2008 Report Posted September 17, 2008 QUOTE (Phantom_Lord @ Sep 16 2008, 07:21 PM) Quote Yes, in fact I've done in a similar way; I've downloaded the circular buffer VI but it doesn't work with my labview version. This is however a simplified version of what is going on in my VI (the FFT here is done on 10 samples and is updated every sample). It is the first time I have seen the use of feedback for implementing a circular buffer. Quote
Scott Carlson Posted September 17, 2008 Report Posted September 17, 2008 Its just an uninitialized shift-register. Only can be hard to decypher if your not used to them. QUOTE (Anders Björk @ Sep 16 2008, 03:39 PM) Quote It is the first time I have seen the use of feedback for implementing a circular buffer. Quote
Anders Björk Posted September 17, 2008 Report Posted September 17, 2008 QUOTE (Scott Carlson @ Sep 16 2008, 10:09 PM) Quote Its just an uninitialized shift-register. Only can be hard to decypher if your not used to them. I have you used they "old" shift registers my impression is that these are hard to read because of the backflowing wires. So I agree. Quote
Phantom_Lord Posted September 18, 2008 Report Posted September 18, 2008 QUOTE (Anders Björk @ Sep 16 2008, 07:39 PM) Quote It is the first time I have seen the use of feedback for implementing a circular buffer. How would you implement it? I used this because it was the first to come into my mind, given my limited knowledge of labview Quote
Marijn Posted December 5, 2008 Report Posted December 5, 2008 Hi, Thanks for the guru example, I had no porblem getting a 2d transform to work. But I can't get the inverse fft to work. Setting the directionality to (1) instead of (-1) for the forward still results in the forward fft. It seems like the call library node doesn't pass the sign correctly to the fftw dll. Do any of you have advice on how to prperly address the fftw dll to obtain the backward transform? Thanks, Marijn Quote
Dirk J. Posted December 23, 2008 Author Report Posted December 23, 2008 Here's an updated example, implementing forward and inverse FFT, in 1D and 2D. enjoy /dirk. Quote
tfroess Posted November 8, 2013 Report Posted November 8, 2013 On 12/23/2008 at 6:10 PM, Dirk J. said: Here's an updated example, implementing forward and inverse FFT, in 1D and 2D.enjoy /dirk. Sorry for the necro post... but I am interested in the FFTw implementation. Has the attachements been removed for old posts? Quote
Yair Posted November 10, 2013 Report Posted November 10, 2013 On 11/8/2013 at 10:54 PM, tfroess said: Has the attachements been removed for old posts? A lot of them were lost in a server crash a few years back. You can clicking the report link on the relevant post and ask the moderators to look for the file, but I wouldn't hold my breath on that, as I don't know what tools they for that and if it's even still possible. If it's a useful file, then someone else might have it. Quote
GregSands Posted November 10, 2013 Report Posted November 10, 2013 I have two zip files from that era which look promising (i.e. they have FFTW in their titles!). LAVA_FFTW.zipFetching info... FFTW_1D_2D__forward_and_inverse.zipFetching info... The Multicore Toolkit is another option for fast, parallelized FFTs. http://sine.ni.com/nips/cds/view/p/lang/en/nid/210525 Quote
tfroess Posted November 14, 2013 Report Posted November 14, 2013 On 11/10/2013 at 8:31 PM, GregSands said: The Multicore Toolkit is another option for fast, parallelized FFTs Thanks for the uploads. I will check them out. "NI LabVIEW Multicore Analysis and Sparse Matrix Toolkit CAD 1,715.00" Pretty hefty price tag for something readily available in other languages for free. Quote
Kas Posted November 20, 2013 Report Posted November 20, 2013 Above FFTW only works for 32 bit versions. It was simple enough to grab the 64 bit DLL version from FFTW website and replace it. Attached is for both 32 and 64 bit version. LAVA_FFTW (32 and 64 bit).zipFetching info... Quote
