smcnally Posted February 8, 2007 Report Posted February 8, 2007 Sorry, I am new to using call library function and don't know where to begin. I tried using the import shared library (.dll) tool to create vi's for each function in my dll. When I load the supplied .h file it seems like my definitions are not recognized. could someone please show me how to create a labview vi for calling the functions in the attached .dll? It's been several years since I've dealt with C code/and defintions and variable types. Thanks Steve M. Download File:post-7342-1170954787.zip Quote
Rolf Kalbermatter Posted February 9, 2007 Report Posted February 9, 2007 Sorry, I am new to using call library function and don't know where to begin. I tried using the import shared library (.dll) tool to create vi's for each function in my dll. When I load the supplied .h file it seems like my definitions are not recognized. could someone please show me how to create a labview vi for calling the functions in the attached .dll? It's been several years since I've dealt with C code/and defintions and variable types. This header file uses a very strange and unusal way to define the function prototypes in the DLL. In fact it does not define any prototypes but just function pointer types. That's definitely not a standard way to incorporate this DLL into once own code even in C. Try to change for all functions DWORD (*MPUSBGetDLLVersion)(void); to DWORD MPUSBGetDLLVersion(void); basically removing the brackets around the function names and also the * in front of the function name and then try to import this again with the DLL import tool. Now it should work. Rolf Kalbermatter Quote
smcnally Posted February 9, 2007 Author Report Posted February 9, 2007 This header file uses a very strange and unusal way to define the function prototypes in the DLL. In fact it does not define any prototypes but just function pointer types. That's definitely not a standard way to incorporate this DLL into once own code even in C.Try to change for all functions DWORD (*MPUSBGetDLLVersion)(void); to DWORD MPUSBGetDLLVersion(void); basically removing the brackets around the function names and also the * in front of the function name and then try to import this again with the DLL import tool. Now it should work. Rolf Kalbermatter Thanks Rolf Another Question. Below is the .h file #ifndef _MPUSBAPI_H_ #define _MPUSBAPI_H_ #define MPUSB_FAIL 0 #define MPUSB_SUCCESS 1 #define MP_WRITE 0 #define MP_READ 1 // MAX_NUM_MPUSB_DEV is an abstract limitation. // It is very unlikely that a computer system will have more // then 127 USB devices attached to it. (single or multiple USB hosts) #define MAX_NUM_MPUSB_DEV 127 DWORD (*MPUSBGetDLLVersion)(void); DWORD (*MPUSBGetDeviceCount)(PCHAR pVID_PID); HANDLE (*MPUSBOpen)(DWORD instance, // Input PCHAR pVID_PID, // Input PCHAR pEP, // Input DWORD dwDir, // Input DWORD dwReserved); // Input <Future Use> DWORD (*MPUSBRead)(HANDLE handle, // Input PVOID pData, // Output DWORD dwLen, // Input PDWORD pLength, // Output DWORD dwMilliseconds); // Input DWORD (*MPUSBWrite)(HANDLE handle, // Input PVOID pData, // Input DWORD dwLen, // Input PDWORD pLength, // Output DWORD dwMilliseconds); // Input DWORD (*MPUSBReadInt)(HANDLE handle, // Input PVOID pData, // Output DWORD dwLen, // Input PDWORD pLength, // Output DWORD dwMilliseconds); // Input BOOL (*MPUSBClose)(HANDLE handle); #endif Labview does not seem to understand PVOID,DWORD,PWORD, and BOOL datatypes. I beleive these are DELPHI datatypes. What would you recommend me using for Labview recognized datatypes instead? also to I need to define my variable name as weill i.e. #define Data void Thanks for the help Steve M. Quote
Rolf Kalbermatter Posted February 9, 2007 Report Posted February 9, 2007 Labview does not seem to understand PVOID,DWORD,PWORD, and BOOL datatypes. I beleive these are DELPHI datatypes. What would you recommend me using for Labview recognized datatypes instead? also to I need to define my variable name as weill i.e. #define Data void These are typical Windows SDK types. But your header file does not include any other header files so it is syntactically not right. A C compiler could not understand it either without additional includes defining those types. Bascially that whole header file looks like a big mess to me. I'm surprised that Microchip does release something like this. There have been various posts here on LAVA and the Developer Exchange showing the actual type definition of those Windows SDK types. Adding them to the top of your header file seems to be the most simple solution. I do not understand your question about defining your own data. I would say no but can't be sure. Rolf Kalbermatter Quote
