yannis Posted February 14, 2007 Report Posted February 14, 2007 Hello I am tring to acquire some digital signals that comes from some switches with a usb6009 board. I really need to determine the timming between these switchings. Apparently the board can't use the timming as this is for analog acquisition. Any idea will help. many thanks Quote
French LVer Posted February 15, 2007 Report Posted February 15, 2007 Greetings yannis, I can see two ways to measure digital timings with usb 6009. USB 6009 has a counter input that will help you determine delays between switchings. Unfortunately, there is only one counter input on your device. The other way is to use free analog inputs to acquire digital signals. I hope that will help you. Quote
i2dx Posted February 15, 2007 Report Posted February 15, 2007 QUOTE(yannis @ Feb 13 2007, 10:57 AM) HelloI am tring to acquire some digital signals that comes from some switches with a usb6009 board. I really need to determine the timming between these switchings. Apparently the board can't use the timming as this is for analog acquisition. Any idea will help. many thanks the bad news first: you need some German to understand the description the good news: http://forum.ib-berger.com/index.php?showtopic=64' target="_blank">check this examle Quote
