LV 8.2 App Builder uses 7.1 RTE?!?!
I'm in the process of creating a new exe of our project. A strange thing keeps happening and I don't know what's wrong. I had LV 7.1 installed on the machine, as well as LV 8.2 to transition to the new version. I created an .lvproj and built a new .exe of our application. Lo and behold, it flashes the LV 7.1 flash screen and then asks me to select the VI I want to run, when i select the main VI of the application, it simply gives me an Error 9 message and says that that vi is compiled in version 8.2 of LV and won't open. I tried right-clicking on a vi and trying to force it to associate with 8.2, that didn't work. I uninstalled 7.1 and the 7.1 RTE entirely and when I try to run my LV 8.2 built exe it STILL manages to use the 7.1 run time from somewhere.
After that I tried to re-associate them with 8.2 yet again to no avail. When i run my exe it just tries to open them in the non-existing 7.1 RTE and re-associates them all with 7.1. Please help, i think this is a bug.
All the exe is, is a splashscreen.vi which calls our main application vi through the vi server. This worked perfectly fine in 7.1 (during distribution, we would just save all of our VIs without block diagrams).
I really need some help with this one. Thanks in advance.
QUOTE(Tomi Maila @ Feb 13 2007, 03:03 PM)
  Quote
Did you follow LV installation order from older to newer. Was all 7.1 components installed first and all 8.2 components after them?
Yes. Everything was installed in proper order. I tried removing all of NI software this morning and then installing just LV 8.2. I still get the same thing. I called NI they don't know what might cause this. The problem is that it did this on 3 different machines.
Basically it looks like windows doesn't want to associate vis with LV 8.2. I tries to use the 7.1 RTE to open all VIs after I run my exe and even if I try to force-associate VIs with LV 8.2 by manually browsing to the LabVIEW.exe i simply get taken back to the Open With dialog box and no version of labview is anywhere in that list.
QUOTE(Aristos Queue @ Feb 13 2007, 05:12 PM)
  Quote
Is it possible that at some point in your EXE that you call a LV-built DLL that was built against LV 7.1? That's the only thing I can think of.
Well we do have dlls, quiet a few of them but the NI engineer I spoke with, said that on his machine everything worked as expected and opened when he ran the exe. The problem with my machine is that even when I create a simple, new exe with a test vi, it flashes the 7.1 screen and gives the open vi dialog box. I'm going a little crazy at this point, will probably have to uninstall everything and use msiblaster. I can post pictures.
QUOTE(jhoskins @ Feb 13 2007, 06:06 PM)
  Quote
Hey j,
That romulus guy is me ;-) So i just cross-posted myself hehe. Still no answer, here's what I added there:
Thanks for the reply. I do understand how bizzare this must seem to you, I had the same reaction. I know perfectly well the behavior of LV built exe, been using it for 5 years. The problem here is the bizzare behavior of the .exe (any in fact, i've built several test vis and exes) on 3 different machines.
I'll try to explain what's happening:
1) I create a new project
2) I add my Test.vi to the project
3) I set my Test.vi as the startup vi (Test.vi simply calls my main vi via the vi reference).
4) I build the exe and execute it
5) Upon execution, an LV 7.1 splash screen pops up for a brief second and I get an Open VI file dialog box asking me to select a VI I want to open, all the VI files inside that window take on the appearance of LV7.1 icons, instead of 8.2. If I try to select a VI from that window, I get LabView load error 9: VI version (8.2) is newer than LabView version (7.1).
I'm used to that error after you recompile a 7.1 vi to 8.2, but I don't even have LV7.1 installed. It seems like the exe is trying to use LV7.1 RTE to run itself instead of 8.2. I though I have 8.2 RTE automatically installed by LV Dev, but I guess not since it doesn't show in Add/Remove Programs menu, but it DOES show up in MAX under software, go figure. I wish I could get someone in NI to look into this. I've never had a problem like this, it is happening on 3 PCs here and is taking up a lot of work time. I have source code I can send as well as a short video of what's happening on my machine.
