Build LV Runtime and DLLs statically into exe
Hello, it's possible to built the LV Runtime and used DLLs into Executable similar to MS Visual Studio? I think so, i don't should to install my application, only start the exe and it runs. However the EXE gets a big size.
Eugen
Basically, no.
However, you can run an LV EXE without installing it (or at least you could before 8.2 and if you didn't use any hardware) by placing the executable in the same folder as the RTE.
You can also do this a little more nicely by using the method described here (I used something similar to have my application as the default option when inserting a USB flash drive).
