JStoddard Posted February 17, 2007 Report Share Posted February 17, 2007 I'm currently doing a VI for a Leak Test machine that may run up to 24 hours. In this time period I'm graphing the collected pressure traces, and that's it. Is there a way to dump the history of the graph to a CSV file? Rather than collecting the data into another array, and then either trashing the array once they start a new test, or saving it to a file if it's involked. It just seems like better memory managment to use the history feature... i guess. Thanks! Jason Quote Link to comment
eaolson Posted February 17, 2007 Report Share Posted February 17, 2007 QUOTE(JStoddard @ Feb 16 2007, 01:46 PM) I'm currently doing a VI for a Leak Test machine that may run up to 24 hours. In this time period I'm graphing the collected pressure traces, and that's it.Is there a way to dump the history of the graph to a CSV file? Rather than collecting the data into another array, and then either trashing the array once they start a new test, or saving it to a file if it's involked. It just seems like better memory managment to use the history feature... i guess. For a chart, you can use a property node and use the History Data property to get the contents of the chart as an array. It will discard everything not contained in the chart history, though. For a graph, you can just use a local variable of the graph itself. I would suggest logging the data to disk as you collect it, though. Unless you're collecting at really high rates, it shouldn't slow anything down. If a power glitch can lose 24 hours of data, it's worth the small amount of extra work. Quote Link to comment
Neville D Posted February 17, 2007 Report Share Posted February 17, 2007 QUOTE(JStoddard @ Feb 16 2007, 11:46 AM) I'm currently doing a VI for a Leak Test machine that may run up to 24 hours. In this time period I'm graphing the collected pressure traces, and that's it.Is there a way to dump the history of the graph to a CSV file? Rather than collecting the data into another array, and then either trashing the array once they start a new test, or saving it to a file if it's involked. It just seems like better memory managment to use the history feature... i guess. Thanks! Jason You mean "chart"? Neville. Quote Link to comment
JStoddard Posted February 17, 2007 Author Report Share Posted February 17, 2007 I did indeed mean a chart. I don't want to always log the data because the defined user has a .01% likely hood of wanting the information saved to a CSV. It's a "i might want to some day" feature. Quote Link to comment
