How to get XControlLibrary reference from XControl Instance
Jim Kring
Does anyone know how to detect whether a VI is calling an XControlLibrary instance (an XControl) and obtain a reference to the XControlLibrary? The XControlLibrary does not show up as in the callees list. It is possible to test all Front Panel controls using the XContro::Is XControl? property but this does not give any information about or link to the XControlLibrary. It is also possible to get this info from the linker info on disk, but I would like to do this all using VI Server, in memory.
QUOTE(Jim Kring @ Feb 18 2007, 12:59 AM)
I don't have a complete answer to you. I did'n quite get it where from did you try to get the XControl reference. From VI where the XC instance is located? Anyhow, you can find out which XControl your control is by getting it's class name using property node. You can find which libraries are in memory of all the applications using property All Libraries in memory of Application. But I still don't know how to get a reference to the library unless you also know the path of the library. If you know the path of the XControl, then it's easy. If you know the name of a Facade.vi then you can open a VI reference to Facade directly from memory by wiring the long name to open VI reference. But I assume you don't in general know this information.
Jim, tell me more about the linker info on the disk. What is it and where can I find it and how can I use it.
Tomi
Thanks Jim,
You can get link from a VI to the XControl library:
XControlName=Control.Class Name AllVIs=Application.All VIs in Memory For each VI in AllVIs {   if (VI match XControlName) resultVI=VI }  XControlLibrary = resultVI.Library
You can get the link from an XControl to Owning VI
ContainerState.Refnum.OwningVI
Tomi
QUOTE(Tomi Maila @ Feb 19 2007, 01:01 AM)
You can get link from a VI to the XControl library [snip...]
You can get the link from an XControl to Owning VI [snip...]
Tomi,
That looks like it will work great. Thank you! :)
-Jim
