Flatten To String for LV 7.x
Hello, my question is:
how can I realize Flatten To String with little endian byte order for 7.x LabVIEW versions? I tryed Swap Bytes and Type Cast VIs, but it fits only interegr data types and not floating point numbers.
Eugen
QUOTE(Eugen Graf @ Feb 22 2007, 03:28 PM)
Eugen
Flatten to string and friends are independent of machine type. So you can use the same data on both Macs and PC's. Flatten/unflatten does the big/little endian rearranging for you.
Joris
QUOTE(robijn @ Feb 22 2007, 05:00 PM)
Joris
Thanks, I know, but this feature for this VI is only available for 8.x versions. I can't convert data from big endian to little endian in 7.x.
QUOTE(JFM @ Feb 22 2007, 05:18 PM)
Oh, thanks, but I want to handle any data undependent on type. So I want to replace Flatten To String with my own VI, that has the same functionality and works under 7.x versions.
The problem is, I have a lot of big clusters with different datas, so I don't want to handle every element others, I want only one VI, that converts every data type.
Eugen
QUOTE(Eugen Graf @ Feb 22 2007, 05:30 PM)
I don't understand you. I was not talking about LV8 specific behaviour, the platform independent flattening was there at least from version 5.
Well, you can connect the various datatypes to the flatten function, but I don't understand why you want to do flattening AND big/little endian reordering. Just flatten and the resulting string can be unflattened on any platform.
You talked about a subVI, maybe you can create one that works with any datatype by using a variant as input.
Joris
QUOTE(jpdrolet @ Feb 22 2007, 11:26 PM)
Try this VI. It uses the Variant Data Tools to recurse into any structure and swap endianess of numbers
Yes, I am happy now. Thanks a lot. :thumbup:
Eugen
