source distribution for previous version
Hello, is it possible to convert all of my project VIs including depencies and all of files to previous version?
I have 8.0.1 and want to convert and distribute for 7.1.
Thanks, Eugen
QUOTE(Eugen Graf @ Feb 23 2007, 05:51 PM)
Is it not posible??? Must I open every VI (of 30) and save they for previous version? What would be if I would have 500 VIs?
I'm not sure what you mean, but you can select your top VI and save that for a previous version. All linked VIs (except those in vi.lib) will also be saved for previous.
Is this what you need?
/J
QUOTE(Eugen Graf @ Feb 23 2007, 04:02 AM)
Thanks, Eugen
No, you can write a VI to do it for you. Open your project, grab all the targets (regular .vi's and dependencies) and save them for a previous version in a new folder. I'll try to make something that will do it for you.
QUOTE(JFM @ Feb 23 2007, 06:28 PM)
QUOTE(ars_stowers @ Feb 23 2007, 07:10 PM)
Something approximately like the attached should help you out. What I'm including is far from fully functional, but it should give you a good starting point. Hope it helps!
Alternatively, just use JFM's solution, it is probably much better. If you are saving it for a prev version, your dependencies should be available on that computer in the previous version anyway.
Thanks, save for previous version in LV includes all depencies automaticaly only if i select a folder in the save dialog. But the VI from ars_stowers is very interesting.
Thanks a lot, Eugen
QUOTE(Eugen Graf @ Feb 23 2007, 07:20 PM)
Thanks a lot, Eugen
If you are converting back to LV7.1 from a LabVIEW 8 project, I would consider making a VI tree to display all Top level methods anyhow, since the project view didn't exist back then.
Have a nice weekend!
/J
Thanks a lot, Eugen
Sorry, I think I start my VIs dynamicaly, and they are not included if I save for previous.
Eugen
