orko Posted February 24, 2007 Report Share Posted February 24, 2007 Hello, The problem that I am fighting against now in my current project can be viewed in this simple VI: Download File:post-3266-1172249715.zip (LV8.0.1) Basically, the problem is a real time-burner in large projects which use typedef constants a lot (for instance in queued message handlers where you are converting variant data to their typdef'd form in multiple cases). Every time you change the typedef, no matter if you have autosizing turned off or not, the constant resizes and makes a mess of the block diagram. I believe this may be related to the following post, but his problem seemed more related to labels: http://forums.lavag.org/index.php?showtopi...t=0&p=24425 -- orko Link to comment
Grampa_of_Oliva_n_Eden Posted February 24, 2007 Report Share Posted February 24, 2007 QUOTE(orko @ Feb 23 2007, 12:00 PM) Hello,The problem that I am fighting against now in my current project can be viewed in this simple VI: Download File:post-3266-1172249715.zip (LV8.0.1) Basically, the problem is a real time-burner in large projects which use typedef constants a lot (for instance in queued message handlers where you are converting variant data to their typdef'd form in multiple cases). Every time you change the typedef, no matter if you have autosizing turned off or not, the constant resizes and makes a mess of the block diagram. I believe this may be related to the following post, but his problem seemed more related to labels: http://forums.lavag.org/index.php?showtopi...t=0&p=24425 -- orko This is a known issue. I can only advise that you use a sub-VI to return the constant and use the sub-VI everywhere the typ-def-d constant would have appeared. Ben Link to comment
orko Posted February 24, 2007 Author Report Share Posted February 24, 2007 Thanks Ben, Does this problem still exist in LV8.2? Link to comment
Please sign in to comment
Sign In Now
