bjarket Posted February 27, 2007 Report Posted February 27, 2007 I would like to change the increment steps in a slide from 1's to 0.1's. The NI homepage describes a solution for LV 8.2, but it doesn't seem to be applicable for LV 7.1, which I'm using. http://zone.ni.com/reference/en-XX/help/37...crement_and_de/ Is there a solution for LV 7.1? Thanks! Quote
Yair Posted February 27, 2007 Report Posted February 27, 2007 As far as I can tell, the only way to change the value in anything other than 1 is either using the shift key or using the up and down arrow keys on the keyboard. Using the increment\decrement buttons will not change the value by 0.1 even in 8.2 if I understand that correctly. You can either use the arrow keys or create your own increment\decrement buttons which will change the value of the slide through local variables. Just be sure to look out for race conditions. Quote
jpdrolet Posted February 27, 2007 Report Posted February 27, 2007 QUOTE(bjarket @ Feb 26 2007, 11:01 AM) I would like to change the increment steps in a slide from 1's to 0.1's. The NI homepage describes a solution for LV 8.2, but it doesn't seem to be applicable for LV 7.1, which I'm using. http://zone.ni.com/reference/en-XX/help/371361B-01/lvhowto/using_the_increment_and_de/' target="_blank">http://zone.ni.com/reference/en-XX/help/37...crement_and_de/ Is there a solution for LV 7.1? Thanks! On the Data Range properties tab of the control, unselect "Use Default Rang" and set Increment to 0.1 Quote
bjarket Posted February 28, 2007 Author Report Posted February 28, 2007 QUOTE(jpdrolet @ Feb 26 2007, 10:09 PM) On the Data Range properties tab of the control, unselect "Use Default Rang" and set Increment to 0.1 Just what I was looking for! Thanks! Quote
Yair Posted February 28, 2007 Report Posted February 28, 2007 QUOTE(jpdrolet @ Feb 26 2007, 11:09 PM) On the Data Range properties tab of the control, unselect "Use Default Rang" and set Increment to 0.1 http://forums.lavag.org/index.php?act=attach&type=post&id=5049''>http://forums.lavag.org/index.php?act=attach&type=post&id=5049'>http://forums.lavag.org/index.php?act=attach&type=post&id=5049 It's always the little things that get you... Quote
