can I get output from DAQ card
siallid
I have the followin hardware:
PCI-6023E DAQ card
SCXI-1001 chassis
SCXI-1803 TBlock
SCXI-1100 Multiplexing and amplification module
and I use Labview 6.1
Now I use this for monitoring analog signals so I can display and save the measured signals.
but I want to ask Can I got an output signal from such a system and if not what hardware may I need to have an output signal.
thankyou
Salaheddin
QUOTE(martin@aerodynamics @ Mar 2 2007, 06:16 AM)
hello siallid,
this is not the NI-Forum, so you should ask NI or just have a look at http://www.ni.com and search for your hardware...
However
PCI-6023E => No analog Output...
So you need diffrent HW... you could use a USB-Module from NI with an Analog Output. I use the USB-6259 (32 Analog Inputs, 4 Analog Outputs)
or another PCI card... => http://www.ni.com
:lightbulb: Hi Martin,
I only want to be sure that PCI-6023E has no analog output.
thanks,
QUOTE(siallid @ Mar 2 2007, 08:35 AM)
Yes I see, I just mean, that you should show a bit more effort, in finding out such easy things...
I didn't new the PCI-6023E bevore as well
So I just started...
http://www.ni.com/
I entered 6023 in the search field...
in the results, I clicked on http://sine.ni.com/nips/cds/view/p/lang/en/nid/10967' target="_blank">NI PCI-6023E
Then I clicked on Specifications
Scroll down to Analog Output
Number of Channels 0
(Time needed to do that: approx. 15 seconds, when ni.com is already open, and you have a good internet connection)
So you see what I mean?
You need less time to find this out by yourself than startin 2 topics here at LAVA...
