aparnap Posted March 3, 2007 Report Posted March 3, 2007 currently we can right click on a control and create a property node or an invoke node. Take a look at this diagram - It's not possible to right click on the wire and create a property or invoke node. Neither is it possible to do so by right clicking on the tunnel. If you want the property node of the control inside the sequence structure, you must right click on the control and create a property node and move it inside the sequence structure. Quote
LAVA 1.0 Content Posted March 3, 2007 Report Posted March 3, 2007 QUOTE(aparnap @ Mar 2 2007, 12:51 PM) currently we can right click on a control and create a property node or an invoke node. Take a look at this diagram - It's not possible to right click on the wire and create a property or invoke node. Neither is it possible to do so by right clicking on the tunnel. If you want the property node of the control inside the sequence structure, you must right click on the control and create a property node and move it inside the sequence structure. If you had such a function, then you had to think about following: You have one Control and one or more Indicators... So how would you know for which Control/Indicator is this property or invoke node? (you could include that in that programm as well) But when you click on a wire which is between some data manipulation functions, (without Control/Indicators) then this option should'n work... Quote
