hma Posted March 23, 2007 Report Posted March 23, 2007 Hi, How can I change the property (blinking) of the all colums in a row of a table by example if a value in a column is wrong ? Thanks in advance Hugo Quote
lraynal Posted March 23, 2007 Report Posted March 23, 2007 The "Blinking" property is not for a particular Cell of a Table, but for the whole table. To change the color of a row, you need a Property Node, with on top the "ActiveCell" (row will be a constant, and column will be conneted to the itération of the For loop representing all the column), and just under the "ActiveCell" a "CellFGColor" to change the color. And if you really want something to blink, you can add all around a while loop (in a parrallel task) where you change the color every X seconds! Good luck! laurent Quote
Bobillier Posted March 24, 2007 Report Posted March 24, 2007 Just look this code for changing color of differents cells . Is inspired from JKI idea. Regards Quote
