2d to 1d Array Conversion
Dear All
In my mueasurement file i have two columns. First column has the value of the variable and second column has the number of times that value occurs in measurement. e.g
Value-----# of times
2--------------3
4--------------1
3--------------2
Values in both clumns are not sorted and re arbitrary.
Based on this example i want to generate a 1 D array which has the value in Column 1 repeated number of times in the second column. The above example will then become a 1 d array as follows.
2
2
2
4
3
3
At average there are 5000 measurements in one file.
Can you please help.
Thanks
QUOTE(sajidsaleem @ Apr 27 2007, 09:56 PM)
Show us what you've tried and we'll try to help. Upload some code for us to look at.
