Mike Matthes Posted May 5, 2007 Report Posted May 5, 2007 Does anyone know if there's a way to programmatically add a new plot area? I don't know how many graphs to create until run-time, and I want to have seperate plots for each graph, all on the same x-axis. Am I overlooking the property I need? Quote
JasonKing Posted May 8, 2007 Report Posted May 8, 2007 QUOTE(Omar Mussa @ May 4 2007, 08:21 PM) It cannot be done. See this http://forums.lavag.org/index.php?showtopic=6675&pid=25957&mode=threaded&start=#' target="_blank">thread. However, I do think it's techhnically possible to add this feature (a lot has changed since I was actively involved in development of the graph, so it's possible I'm wrong), so I'd suggest submitting a feature request and detailing how you would use the feature/what problem you're trying to solve. It always helps to have concrete use cases to support the desire for a feature, and helps us make sure we get it right. J Quote
Mike Matthes Posted May 10, 2007 Author Report Posted May 10, 2007 QUOTE(JasonKing @ May 7 2007, 11:53 AM) However, I do think it's techhnically possible to add this feature (a lot has changed since I was actively involved in development of the graph, so it's possible I'm wrong), so I'd suggest submitting a feature request and detailing how you would use the feature/what problem you're trying to solve. It always helps to have concrete use cases to support the desire for a feature, and helps us make sure we get it right.J I'll be sure to do that (make some product suggestions) once I get a chance. I followed the other thread and it was very interesting. In general I have to say that I ran into the exact same bugs, so it must be a fairly common thing to do to try and move scales around, graphs to different plots, etc programatically. As for use cases, in general you could take every XY graph property / method and assume that we'll want to do the same thing with the Muliti-plot. I have many uses where I just want a common X axis, and this has provided a great tool for these. I think it was one of the better additions to 8.0 feature-wise, it just has some more development to get to the maturity of the other graphs. Quote
Bobillier Posted May 12, 2007 Report Posted May 12, 2007 Hi why you don't use few graph look like MSG ? See my exempl.(run with graph, chart,numerical graph,XY graph) Eric Quote
