problem when editing sub pallet icons with non standard vi editor
For those that are using my icon editor or other home made editor using the lv_icon.vi option
There is a LabVIEW LOCKUP problem when trying to edit a sub pallet in the pallet editor.
If you open the pallet editor.
http://forums.lavag.org/index.php?act=attach&type=post&id=5754
and then try to edit a sub pallet menu icon
http://forums.lavag.org/index.php?act=attach&type=post&id=5755
Nothing happens.
The icon editor is running in the background but it is somehow being suppressed by the pallet editor.
If you are using my editor or you have set the lv_icon.vi to a non modal state then there is a work around.
for Windows press (CTRL-Space-x) and the editor should maximize and work normally.
If the icon editor is set to a modal or floating state then you are out of luck.
I was unable to get LabVIEW back without the 3 finger salute (CTRL-ALT-DELETE)
By default the lv_icon.vit and Sample_lv_icon.vi are set to Dialog which is modal.
http://forums.lavag.org/index.php?act=attach&type=post&id=5757
So if you are going to create your own icon editor I would recommend setting the Windows appearance to default.
http://forums.lavag.org/index.php?act=attach&type=post&id=5758
I have reported this issue to NI.
My thanks to tcplomp for finding this bug and the work around.
  • 3 weeks later...
  • 4 weeks later...
  • 9 months later...
