Generice way to distribute U8 to various clusters
http://forums.lavag.org/index.php?act=attach&type=post&id=5767http://forums.lavag.org/index.php?act=attach&type=post&id=5769
I hope someone can help me think of a way to do the following. I'm getting data from hardware (always U8) that I need to distribute to a series of clusters. Each cluster can consist of various combos of booleans and numerics that total to 8 bits (see an example cluster in the attached VI which is explained below). I need to somehow divide up the incoming bits to the cluster elements. I was hoping to find a generic way of doing this instead of needing a pile of case statements. It would make maintenance easier to when I have to add more clusters. I put the format in the clusters caption that shows how many bits are in each part of the cluster (for the attached VI the caption would contain 1_3_1). I can retrieve the caption in the subVI and that at least gives me some idea on how to distribute the data. I just can't figure out how to bundle the data to send it back to the cluster.
Here's one thing I tried. I converted the cluster (via a reference and then to a variant) to XML, changed a few values in the XML based on the incoming data and then tried to convert back again to a variant to send to the cluster reference value (see attached VIs). Converting to XML is easy, but I get an error when converting back to a variant that says that "the data type of the variant is not compatible with the data type wired to the type input". Is there any way to convert back to a variant? It's easy when the actual cluster is available, but I need to do the conversion in a subvi with a reference to the cluster.
George
